GATOR Posted May 8, 2014 Posted May 8, 2014 I am animating constraints and as i am previewing the video the part seam to move with a pause motion. I don't know if this would go away once i render the animation and if it doesn't how can i change this? I have seen samples with a smooth rotation and i would like to achieve similar results. Thank you, Gator Quote
JD Mather Posted May 8, 2014 Posted May 8, 2014 Most likely your video card can't keep up (you haven't supplied any system spec information). It should render OK. My recommendation is to keep animations under 30-seconds and if longer period is needed - use something like Microsoft Movie Maker (free) to stitch them together. Quote
GATOR Posted May 8, 2014 Author Posted May 8, 2014 Thank you... the render came out fine and yes my video card needs to be upgraded Quote
