Bender Posted May 9, 2014 Share Posted May 9, 2014 Is it possible for me to assign some text objects who have the same linecolor to a new layer? or do i need to assign them manually? Quote Link to comment Share on other sites More sharing options...
dbroada Posted May 9, 2014 Share Posted May 9, 2014 Are you saying you want to select all the (for example) green text that is on one layer and move it to another? If so, you can QSELECT (or select similar) the text and while it is highlighted change its layer with the properties palette. The move can also be achieved with the layer toolbar. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 9, 2014 Share Posted May 9, 2014 One option: You could create a new layer then use the CHANGE command to change the layer the text appears on. Change > Properties > LAyers. Quote Link to comment Share on other sites More sharing options...
