Tiger Posted May 20, 2014 Posted May 20, 2014 Like ReMark said, the "proper" way to do it is to have a template file with your settings in them. A way to get all the styles you want into your template file is to open both your current template file and the file that you want to take styles from, then use Design Center to drag and drop the styles from one drawing to the other. It is better than useing an old file that you remove all the objects from. It is not uncommon for files to get corrupted, bloated and troublesome over time, and to use a file like that as a basis for a new design, is generally a bad idea. Quote
