Netminder Posted May 15, 2014 Posted May 15, 2014 I have tried several ways to either emboss letters and images on a 2.0" diameter coin or to create them using a sketch on the face. I continue to get a "self intersecting loop" error. Any suggestions for this problem and should I emboss or create with sketch. Thanks, Go Habs! COIN.ipt Quote
JD Mather Posted May 15, 2014 Posted May 15, 2014 Change your font to something less complicated or sketch the letter yourself. Complicated fonts will not work. Quote
Netminder Posted May 19, 2014 Author Posted May 19, 2014 JD - like usual your advice was spot on. The simpler block style fonts work like a charm. Thanks, Scott Quote
Lazer Posted May 29, 2014 Posted May 29, 2014 Strange the emboss worked fine with the text you had using my machine. You may need to get the latest service pack or as JD said just change the text, glad you got it sorted Quote
