tmp Posted May 19, 2014 Posted May 19, 2014 :?Hi, i 'm a new user in C3D. May i know what is the simple way to know the volume in a drawing? what should i have to know the details or info to find volume? Quote
JerryG Posted May 19, 2014 Posted May 19, 2014 Tmp. Welcome to the forum! But you might want to start a new thread as opposed to jumping on one already started with a different subject. Quote
Tiger Posted May 19, 2014 Posted May 19, 2014 Hi Tmp, I moved your question to its own thread. Do you mean a volume between two Surfaces? Easiest way is the command REPORTSURFACEVOLUME. Most common/stable way is with the Volumes Dashboard that you find on the Analyze-tab. There you can create a Differential Surface between to surfaces. Quote
tmp Posted May 20, 2014 Author Posted May 20, 2014 JerryG, thx....for the remind of my mistake:lol: Quote
tmp Posted May 20, 2014 Author Posted May 20, 2014 (edited) Hi Tmp, I moved your question to its own thread. Do you mean a volume between two Surfaces? Easiest way is the command REPORTSURFACEVOLUME. Most common/stable way is with the Volumes Dashboard that you find on the Analyze-tab. There you can create a Differential Surface between to surfaces. Bingo ~ Tiger, this is what i want, but still a bit confusing with the steps. May try in error... ha..ha...at last ...it's succeed. thx...thx Edited May 20, 2014 by tmp Quote
