Installing a .Vlx file into Autocad LT 2014
stratozsphere
Hi,
Ive been searching all over to try and work out how to install a simple .vlx file into my Autocad as I have the need to add up multiple lines and doing it via calculator is just tedious!
I have Autocad LT 2014 is this due to it being an LT version a none of the recommended commands work. If so is there a way around it without having to fork out for the full version? I just need to do this one simple thing!!
Thanks in advance
Kim
