brow_tines Posted May 26, 2014 Share Posted May 26, 2014 I'm working on a simple drawing for a guy that needs a name cut out of metal using a CNC plasma cutter. What font can I use to use so I can also use the boundary command? Or do I have to trace out the letters then use the BO command? thanks for the help and advice Quote Link to comment Share on other sites More sharing options...
Dadgad Posted May 26, 2014 Share Posted May 26, 2014 I should think you could use the Express Tool Explode Text, after which you could use the PEDIT command, with MULTIPLE selection and JOIN them into closed polylines. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 26, 2014 Share Posted May 26, 2014 You should be able to use any font that is not composed of single line/arc segments. Quote Link to comment Share on other sites More sharing options...
BIGAL Posted May 27, 2014 Share Posted May 27, 2014 Google TEXT TO GEOMETRY cool program to export text out as Autocad objects Line plines etc. Text2geom.dll. I think its over at Theswamp Quote Link to comment Share on other sites More sharing options...
