What you failed to point out in your abbreviated response
Not everyone on the forum has time to provide such detailed responses, spelling out every single step of every procedure complete with screen grabs, diagrams and illustrations. We are all here to help each other, but the extent of help, that we are each able to provide, is determined by each forum member individually.
Knowing the name of the command that needs to be used should be enough information for most people to then do a little research and experimentation on their own. If they have problems they can always come back and ask further questions.
If you want to create detailed tutorials for every member who asks a question, that is your prerogative, but please don't expect, or demand, that everyone else to do the same.
  • Replies 21
  • ReMark
    9
  • sublimekid
    4
  • JD Mather
    3
  • davorka
    3
Posted Images
I did not expect a detailed, step-by-step tutorial. All the responder had to do was explain that revolving a series of lines does not a solid make.
Edited by ReMark
