Point Style Symbols,Out of Scale Y Direction C3D 2014
Hello,
Has anyone experienced disproportional scaling in the Y direction when dealing with Point Styles. Despite having the same dimensions as east west similar symbols such as a sign, the north south sign displays considerably smaller. Have tried everything but can not get it to work.
Any insight would be appreciated.
Thanks!
rlshound
Welcome to the world of styles, my degree is in style manipulation is going well :D.
You need to post a dwg so we can have a look.
Hello BIGAL, the template drawing exceeds the limit to post at 2,894 KB...your thoughts? rlshound
Just copy and paste a bit to a new blank dwg make sure its the same DWT.
Ok....here is a sample of the point styles, description keys and settings from the proposed template. One to follow....Thanks
TRUE.dwg
Morning BIGAL, Thanks for taking the time to look into this.....still can't find the reason for this....if and when I figure it out I'll get back to you....Thanks Again! rlshound
