Arizona Posted June 11, 2014 Posted June 11, 2014 ACAD Civil 3D Land Desktop Companion 2009 This happens every once and a while and I've long been curious to what is going on. I run an audit, it finds errors. Run the audit again, no more errors. Purge. -the only thing it removes is one layer: $AUDIT-BAD-LAYER Run audit again -all the same errors are found again. After the audit, $AUDIT-BAD-LAYER is empty. No entities on that layer. Multiple methods confirm that the layer is empty. So - why does removing the layer $AUDIT-BAD-LAYER recreate the errors?! What exactly is going on there? Even if I just delete the layer via the layer dialog box, instead of purging, the errors return. Below is what Audit is returning on the drawing this is happening in this morning. Command: AUDIT Fix any errors detected? [Yes/No] : Y Auditing Header Auditing Tables Auditing Entities Pass 1 Pass 1 3100 objects audited Auditing Entities Pass 2 Pass 2 2400 objects auditedAcDbLine(112E6) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(112E7) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(112E8) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(112E9) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbMText(112EA) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbSolid(112EB) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbSolid(112EC) Invalid layer eWasErased $AUDIT-BAD-LAYER Pass 2 2500 objects auditedAcDbLine(112F0) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(112F1) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(112F2) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(112F3) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbSolid(112F4) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbSolid(112F5) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbMText(112F6) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(112FA) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(112FB) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(112FC) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(112FD) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbSolid(112FE) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbSolid(112FF) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbMText(11300) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(11304) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(11305) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbLine(11306) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbSolid(11307) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbSolid(11308) Invalid layer eWasErased $AUDIT-BAD-LAYER AcDbMText(11309) Invalid layer eWasErased $AUDIT-BAD-LAYER Pass 2 3100 objects audited Auditing Blocks 81 Blocks audited Total errors found 27 fixed 27 Erased 0 objects ********* Funny how "8"+")" returns the cool dude smilie. ********* Thanks in advance for any light you can shed on this strange phenomenon. -Jeff Quote
RobDraw Posted June 11, 2014 Posted June 11, 2014 That is one bad layer. It can drive one nuts when trying to get rid of it. For me, it often appears after running a purge or an audit. In my case, it appears most often when I'm dealing with files exported from Revit. I haven't been able to find what is causing that layer to appear. Using LAYDEL usually gets rid of it permanently. My theory is that, along with deleting the layer, the entity causing the error is also deleted. I don't think that the entity has anything on that layer. It just causes an error that creates the layer. Thusly, you are able to delete it, only to have it reappear. Quote
Arizona Posted June 11, 2014 Author Posted June 11, 2014 Well, strange as it may seem, closing the drawing and reopening it cured the problem. Upon reopening, the errors were gone. Kind of like the old rule - when in doubt, reboot. But, Rob - I had no prior knowledge of the LAYDEL command! It's Awesome! Tried it out, and thats a keeper. Thank You! Quote
RobDraw Posted June 11, 2014 Posted June 11, 2014 It is a powerful one. Be aware that it does delete everything that is on the layer, blocks, objects within blocks, etc. Quote
Arizona Posted June 11, 2014 Author Posted June 11, 2014 Objects within blocks? Wow. That's different. I need to do more testing before I let 'the users' know about it...... Quote
Dadgad Posted June 11, 2014 Posted June 11, 2014 That is one bad layer. It can drive one nuts when trying to get rid of it. For me, it often appears after running a purge or an audit. In my case, it appears most often when I'm dealing with files exported from Revit. I haven't been able to find what is causing that layer to appear. Using LAYDEL usually gets rid of it permanently. My theory is that, along with deleting the layer, the entity causing the error is also deleted. I don't think that the entity has anything on that layer. It just causes an error that creates the layer. Thusly, you are able to delete it, only to have it reappear. Should LAYDEL fail to do the trick, and only suggested as an imperfect workaround, for an imperfect drawing you can use LAYMRG and merge it into your 0 layer, or any other you deem the most appropriate. I used to have that happen a lot with a macro I use for final -Purge and Audit of finished drawings. I never really figured it out either, but there were no Revit issues involved with mine. It hasn't happened for a long time now. I would always run the regular PURGE after running my macro to make sure that it hadn't generated such a bad layer. Just remember there aren't any REALLY BAD layers, just BAD draftspeople, present company excluded. Quote
RobDraw Posted June 11, 2014 Posted June 11, 2014 Yeah, I was actually afraid to use it for cleaning up backgrounds for quite a while because of that. Quote
RobDraw Posted June 11, 2014 Posted June 11, 2014 LAYMRG was my "safe" alternative until I was comfortable with deleting. Quote
