Guitte Posted June 30, 2014 Posted June 30, 2014 Im having difficulty to Extrude and to Trim Multiple lines to a line. I found that some of my lines have a Z-axis value, while working the whole time in 2D. Have check all the lines they are set to 0. Now, when I extrude the lines move tiny steps toward the end line. When I trim, it trims in pieces, this brings tears to my eyes to see my progress. How do I correct this problem before I start a drawing? When I start to have this problem, I used Trim/Project/View now im playing with View and None to see which one works eventually... now nothing works. Another post viewed different alignment commands and I don't find it on ACad LT. Typing in ALIGN im not sure what I should select with "first source point" and "destination point" is this only for one line or object? My problem became worse, every day and need to search and try another trick. Quote
ReMark Posted June 30, 2014 Posted June 30, 2014 Did you mean to write "Extend"? The variable you need to change is called EDGEMODE. ALIGN will work on a single line or an entire object (like a block). It's proper use should be covered in your AutoCAD Help file. Quote
Guitte Posted June 30, 2014 Author Posted June 30, 2014 Yes, thank you Remark. I even played with EDGEMODE setting it to 1 then to 0. Not sure anymore which of the threads to use, cause I still stuck with extend and trim. Quote
ReMark Posted June 30, 2014 Posted June 30, 2014 Is it possible that some of your lines still have a Z greater than zero? Attach a copy of the drawing to your next post. Someone here will take a look at it. Quote
Guitte Posted June 30, 2014 Author Posted June 30, 2014 Having tried all these methods, can it be that if someone else is using the same drawing and modifies it, that the settings on the other persons AutoCAD is different than mine and can cause these problems? Quote
ReMark Posted June 30, 2014 Posted June 30, 2014 The setting for EDGEMODE is saved in the Windows Registry and not in the individual drawing. Please attach a copy of the drawing to your next post. Thank you. Quote
Guitte Posted June 30, 2014 Author Posted June 30, 2014 ReMark, im not sure how to insert a drawing. Quote
ReMark Posted June 30, 2014 Posted June 30, 2014 Click on the Go Advanced button and at the next screen click on the Paperclip icon (Attachments). Quote
Guitte Posted June 30, 2014 Author Posted June 30, 2014 The drawing is a bit big, will see if I cant make it smaller Quote
ReMark Posted June 30, 2014 Posted June 30, 2014 Run these three commands on it... 1) Overkill 2) -Purge twice in a row (Regapps first; All second) - note: MUST precede command with a dash as shown 3) Audit Quote
Guitte Posted June 30, 2014 Author Posted June 30, 2014 Have done it, selected 'ALL' to be '-purge' both extend and trim is still the same. Quote
ReMark Posted June 30, 2014 Posted June 30, 2014 The commands I suggested that you use were for reducing the file size and fixing any database errors only. They have no affect on the Extend and Trim commands. Please attach the drawing to your next post. Thank you. Note: If the file size is still too big try zipping the drawing file first then attaching. Quote
Guitte Posted June 30, 2014 Author Posted June 30, 2014 I have taken out all the hatching and only left a section view in, still it exceeds with 71MB. Ill try to delete more objects/lines to min the size and do the "OVERKILL" Quote
ReMark Posted June 30, 2014 Posted June 30, 2014 Am I reading that correctly? The drawing file size is 71MB? If it is I doubt very seriously you'll be able to reduce the file size enough to attach it to a post. The only option would be to upload it to a file sharing site like Dropbox and post a link to it here. Quote
Guitte Posted June 30, 2014 Author Posted June 30, 2014 Sorry, I feel like burning out here. I can only load 1KB, my drawing is 1.71KB. How do I Link the drawing? Quote
Guitte Posted June 30, 2014 Author Posted June 30, 2014 Can only load 1KB, my drawing is 1.71KB, how do I post a link? Quote
ReMark Posted June 30, 2014 Posted June 30, 2014 You would need to set up an account at Dropbox or another file sharing website. Or... ...you can give us your email address, via a post, in this form: m y e m a i l a d d r e s s AT h o t m a i l DOT c o m. Someone will contact you and you can then email the drawing to them. Quote
Guitte Posted June 30, 2014 Author Posted June 30, 2014 Would my email address remain private on this post? Quote
RobDraw Posted June 30, 2014 Posted June 30, 2014 Now, when I [extend] the lines move tiny steps toward the end line. When I trim, it trims in pieces, This sounds like you are not selecting the line that you want to TRIM/EXTEND to. If you do not make that selection, AutoCAD automatically will TRIM/EXTEND to the nearest entity. Start the command and follow the prompts given at the command line. Quote
Guitte Posted June 30, 2014 Author Posted June 30, 2014 Hi Rob, True, I find it much easier, faster and convenient to select trim/extend r-click and let AutoCAD automatically select the nearest entity. And yes I have tried the long way where you have to select the line where you want to trim/extend to and select the line. Just don't know why all of a sudden one has to change what you are use to? If it can be sorted, ill be a happy chappy. Quote
