jamami Posted July 4, 2014 Author Share Posted July 4, 2014 Brilliant, thank you for this. I will download and attempt myself. Quote Link to comment Share on other sites More sharing options...
jamami Posted July 4, 2014 Author Share Posted July 4, 2014 I’m a little late to the party once again but thought I would post an alternate method based on the use of this free plugin at the Exchange:http://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3astsc_uvvectormap_windows32and64%3aen See the attached PDF. This has been interesting. I have eventually worked out a way to do this using AutoCad standard features and reuiring no eyeballing or sketching. - Draw centreline of wire in each elevation. - Increase the length of the 26.08 rad main arc a bit both ends. - Break the 26.08 rad arc at the mid point - Extrude a surface from the side profile arcs - Align the end views each side of the surface. - Use the Project Geometry commands to project the end views onto the surface(I used Project to two points and simply selected the X axis) -Join the 2 sides together -extrude circle along the spline path. QED.... Quote Link to comment Share on other sites More sharing options...
jamami Posted July 4, 2014 Author Share Posted July 4, 2014 Project Geometry is on the Surface tab Quote Link to comment Share on other sites More sharing options...
jamami Posted July 4, 2014 Author Share Posted July 4, 2014 I’m a little late to the party once again but thought I would post an alternate method based on the use of this free plugin at the Exchange:http://apps.exchange.autodesk.com/ACD/en/Detail/Index?id=appstore.exchange.autodesk.com%3astsc_uvvectormap_windows32and64%3aen See the attached PDF. got there in the end, many thanks to all those who helped. Quote Link to comment Share on other sites More sharing options...
SEANT Posted July 5, 2014 Share Posted July 5, 2014 Nicely done. Quote Link to comment Share on other sites More sharing options...
ReMark Posted July 5, 2014 Share Posted July 5, 2014 Good job. Glad to see you stuck with it and did not give up. Quote Link to comment Share on other sites More sharing options...
JD Mather Posted July 5, 2014 Share Posted July 5, 2014 (edited) Take pride in that you figured out how to do it (pretty much) on your own. Good work. Edited July 5, 2014 by JD Mather Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 5, 2014 Share Posted July 5, 2014 Very impressive, well done! Quote Link to comment Share on other sites More sharing options...
mikekmx Posted July 5, 2014 Share Posted July 5, 2014 agreed. very good. Quote Link to comment Share on other sites More sharing options...
