FIFTHTEXAS Posted July 1, 2014 Share Posted July 1, 2014 hi can anyone tell me how to change settings in plot settings my single lines are coming out thicker than my polylines when i plot they are fine on my screen, but when i plot it is opposite to what i require seems my ssettings are set to non-polylines to plot thick. how can i change settings? much appreciated Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 1, 2014 Share Posted July 1, 2014 The screen display does not display line width as it will plot, except in plot preview. Check your lineweight width setting, either in layer properties or object properties. If object properties lineweight is set to By Layer then the lineweight is controlled by the layer property. If the object property lineweight is not set to By Layer, then that specific object lineweight is plotted at that specific width. Quote Link to comment Share on other sites More sharing options...
FIFTHTEXAS Posted July 1, 2014 Author Share Posted July 1, 2014 i have had this happen to me a few times now and baffled why i keep getting this. for example i have created a block., a diffuser set on layer 0, i have made outline of diffuser in bold using polyline at 10 mm width, then using and single line at default. everything looks fine, until i come to print preview then i get the opposite, the polyline is thin and the single line is thick. why is this happening how do i change the setting. i have checked all width settings in my layer manger and they are on default. rest of drawing is ok can you advise please, many thanks Quote Link to comment Share on other sites More sharing options...
RobDraw Posted July 1, 2014 Share Posted July 1, 2014 Educate yourself on plot styles and pen settings. There is probably a tutorial here and many more guides on the internet. Come back with anything specific that you might have questions about. Quote Link to comment Share on other sites More sharing options...
rkent Posted July 1, 2014 Share Posted July 1, 2014 Just another guess, when plotting, uncheck the Scale lineweights option at the lower middle portion of the plot dialog box. Quote Link to comment Share on other sites More sharing options...
Dana W Posted July 1, 2014 Share Posted July 1, 2014 i have had this happen to me a few times now and baffled why i keep getting this.for example i have created a block., a diffuser set on layer 0, i have made outline of diffuser in bold using polyline at 10 mm width, then using and single line at default. everything looks fine, until i come to print preview then i get the opposite, the polyline is thin and the single line is thick. why is this happening how do i change the setting. i have checked all width settings in my layer manger and they are on default. rest of drawing is ok can you advise please, many thanks We need to stick to AutoCad terminology. Also, is this a 3D drawing or 2D? There are a number of ways to control the printed width of a line or polyline. First is the property control "lineweight", is that what you are referring to? Can you make a drawing with just this block in it and attach it here for us to look at? Make sure the drawing has ALL the template values of your working drawing. Just make a copy under another name and erase everything but the block. Quote Link to comment Share on other sites More sharing options...
