nicnicman Posted December 9, 2008 Share Posted December 9, 2008 Hi everyone, Is there a way to dimension with text? For example, instead of Cad automatically giving a measurement I'd like to be prompted for text. I've edited the dimension after it was made but I was hoping for an easier process. Thanks for any help. Nick Quote Link to comment Share on other sites More sharing options...
Dipali Posted December 9, 2008 Share Posted December 9, 2008 changing dimassoc value '0' will give you desired result. But it will result into exploded dimension so the dimension ticks & extension lines & dimension lines all will be seprate line objects. but it is not good practice to creat exploded dimensions or text overrides. Quote Link to comment Share on other sites More sharing options...
nicnicman Posted December 9, 2008 Author Share Posted December 9, 2008 Thanks a lot dipali. I'm labeling groups of trusses on a truss plan and the measurements are not necessary. I'd rather not explode the dimensions but it seems CAD is not giving me a choice. If you have any other suggestions please let me know. Quote Link to comment Share on other sites More sharing options...
profcad Posted December 9, 2008 Share Posted December 9, 2008 As you dimension you can right click and select Text or Mext. A menu macro could be used to pick the points and AutoCAD default to the text option and prompt you for the text. ^C^C_dimlinear;\\text;\ Quote Link to comment Share on other sites More sharing options...
JBullseye74 Posted December 9, 2008 Share Posted December 9, 2008 Yes Or you can select desired dims - open properties and overide the Dims with your References. This can be done with multiple dimensions with the same references. Quote Link to comment Share on other sites More sharing options...
Tankman Posted December 17, 2008 Share Posted December 17, 2008 Yes Or you can select desired dims - open properties and overide the Dims with your References. This can be done with multiple dimensions with the same references. Text overide is one of my best friends! Keep it simple, keep it clean. Quote Link to comment Share on other sites More sharing options...
mugshot Posted December 17, 2008 Share Posted December 17, 2008 dimension... dli/dan/etv. >Specify first extension line origin or :Specify second extension line origin:Specify dimension line location or [Mtext/Text/Angle/Horizontal/Vertical/Rotated]:T (input the text you like)Specify dimension line location or click the place where you like to put. Quote Link to comment Share on other sites More sharing options...
