Is it possible to create new layer using command prompt without layer properties manager............if any one knows please help me
Welcome to CADTutor. :)
Alt + N will do it, though not with a command prompt, nor AT the commandline.
The new layer will have the same properties as your current layer, and you will
be prompted to create a new name for your new layer, after which you will probably
want to make other changes, such as layer color, linetype, etc.
Perhaps that is not the case.:huh:
In the layer properties manager, it shows that as the shortcut
for new layer creation, but I just tried it, and it did not work on my computer.
Not sure why, your results may be different than mine, hope so. :|
Just call the -LAYER command - please notice the hypen in front, this will initiate the prompt version of command. It works for other commands, too.
I'll also second Dadgad and say welcome to the Forum!
Mircea,
Thank you for your advice, -LAYER is exactly matched what I meant................:D
regards,
narendra
Glad I could be of help; you're welcome Narendra!
