Isometrics - Any way to Pre-fix weld numbers with W-xxx ?
This is driving me crazy, I want to prefix my weld numbers with W so instead of 1,2,3,4 it becomes W-1, W-2, W3 etc.
Is this possible? we have Autocad Plant 3D 2013.
  • 4 weeks later...
i am not sure how much different the settings is in the AutoCAD plant 3D compared to AutoCAD P&ID.
however have you found the welded symbol in the project settings?
because the might just be a simple matter of configuring your Propertyp Type under this symbol/fittings?
