Toggle layer
takeanosan
I'm looking to toggle a selection of layers that has the h- prefix.
Found this on the net but it seems to only turn on the layer.
Is there anything I missed or any other way?
Thanks
defun c:test ()
(if LAYGROUPTOGGLE
   (command "_.-layer" "off" "h-*" "")
   (setq LAYGROUPTOGGLE 1)
   (command "_.-layer" "on" "*h-*" "")
   (setq LAYGROUPTOGGLE NIL)
  • Replies 22
  • takeanosan
    10
  • Tharwat
    8
  • pBe
    4
  • Lee Mac
    1
Welcome to CADTutor . :)
This is enough to off layers that are started with h-*
(defun c:test ()
Ah, I wasn't trying to achieve that.
I was rather trying to assign toggle these layers on and off automatically.
My idea was to either:
-check if those layers are on, then turn it off; check if layers are off, then turn it on
-manually create a variable where every time I run the lisp, the value of the variable toggles: where if variable=nil, turn layer off; variable=1, turn layer on
Much thanks.
Toggle Tharwat, The key here is Toggle my friend :)
Much thanks.
Does it have to be all matching layer names to toggle? what if some of them are turned off and some are not?
Yes, all matching. It does not matter to me if some of them are already on/off.
Owh and thank you Tharwat for the warm welcome.
I'm surprised you noticed. =)
Try this .
(defun c:on-off (/ on_off l nm layers v e)
 ;;    Tharwat 22.July.2014        ;;
 ;; Toogle Layers that their names is    ;;
 ;; started with h-            ;;
 (defun on_off (code ent) (entmod (subst (cons 62 code) (assoc 62 ent) ent)))
 (while (setq l (tblnext "LAYER" (not l)))
   (if (wcmatch (setq nm (cdr (assoc 2 l))) "h-*")
     (setq layers (cons nm layers))
 (foreach layer layers
   (if (minusp (setq v (cdr (assoc 62 (setq e (entget (tblobjname "LAYER" layer)))))))
     (on_off (abs v) e)
     (on_off (- v) e)
I can't seem to make it run, nor do I understand enough coding to check for any mistakes. REGEN does not help. Unloaded all my other lisps so ruling out any conflicts.
Here is my list of commands:
Command: -LAYER
Current layer: "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: off
Enter name list of layer(s) to turn off or
Command: *Cancel*
Command: ON-OFF
Command:
Command: *Cancel*
Command: -LAYER
Current layer: "0"
Enter an option [?/Make/Set/New/Rename/ON/OFF/Color/Ltype/LWeight/TRansparency/MATerial/Plot/Freeze/Thaw/LOck/Unlock/stAte/Description/rEconcile]: on
Enter name list of layer(s) to turn on: h-*
Command: ON-OFF
Anything else I could help out with?
How did you run the routine ? can you explain the steps ?
drag, drop into AutoCAD.
Also tried appload after your question.
Pretty sure I loaded it correctly.
One of the proper ways as follows :
Save the code to any name you want but it good habit to save with the same name of the lisp command and with the extension .lsp
Then from autocad call the command appload to load the lisp file then LOAD from the prompted dialog box then close it .
Finally type on-off to call the lisp function .
Note: you should have layers that started with h- as you have asked the routine for in your first post .
Let me now .
Are you sure that you have previous said layers in that drawing ?
Upload a sample drawing if you can .
Perhaps something as simple as this one
(defun c:test nil
 (if (zerop
(setvar	"useri1"
	(Boole 6 (getvar "useri1") 1)
   (command "_.-layer" "off" "H-*" "")
   (command "_.-layer" "on" "H-*" "")
Thanks for the tips Tharwat.
Here is a sample of the drawing:
pBe, your code works! I'm pretty much pleased with it. Though do you mind explaining?
(defun c:test nil
 (if (zerop ;<<<can't understand this
(setvar	"useri1" ;I assume this is setting up a new variable
	(Boole 6 (getvar "useri1") 1) ;<<<also can't understand this
I hope I am not asking too much.
Thanks a lot for all the help.
Sure
(defun c:test nil
 (if (zerop			;<-- test if value is zero
			;<-- T for 0
			;<-- Nil other than 0
(setvar	"useri1"	;<-- System Variable where you can store
			;<-- an integer [Hence user[b]I[/b]1] I for integer
			;<-- Saved in drawing
;<-- Now for Boole, its more complicated
;<-- Click on the link below [by LM]
;<-- What it does is gives the value 1
;<-- if current is 0 and vice versa
Boole
My routine did not work for you because the prefix of the your desired layers to toggle are starting with capital letter and not small letter as you have requested in you first post .
Change the prefix from h- to H- in my routine and it should work .
Ahhh, silly me.
I was oblivious to the case since autoCAD is usually not particular with cases. E.g. during the find command.
I would have guessed it is some stupid mistake on my side.
Anyway my apologies and once again thanks for all the help.
Ahhh, silly me.
:D
Its okay .
