Karynlisa99 Posted July 23, 2014 Share Posted July 23, 2014 Hi, I have just downloaded the new 2015 AutoCAD lt, and I like to edit two of my hotkeys but can't remember how to do it. That is change the actual hot keys Please can someone refresh my memory. thanks Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 23, 2014 Share Posted July 23, 2014 I believe that you want to go to your CUIX, and peruse and redefine the circled items in KEYBOARD SHORTCUTS. I use Autocad Vanilla, not LT, but I am guessing this will be the same. Quote Link to comment Share on other sites More sharing options...
Karynlisa99 Posted July 28, 2014 Author Share Posted July 28, 2014 Hi, thanks for that, but these are the shortcut keys, which require "CTRL" before. I want to change the hotkeys, when I type CO which is short for Copy, I want to change this to just C I keep looking thanks anyway.. Quote Link to comment Share on other sites More sharing options...
CaddJax Posted July 28, 2014 Share Posted July 28, 2014 Use the Manage Tab and then the record feature or you can Edit Aliases if you're doing a lot of changes. The bottom of this message is a list of the one's that I use which allows me to essentially shut down the ribbon and keeps all of my commands within easy reach of only my left hand. Left on the keyboard, right on the mouse. Once you get the hang of it, you'll fly. Good luck. A, *ARC AXX, *ATTIN AX, *ATTOUT AQ, *APPLOAD AR, *-ARRAY BA, *BASE H, *BHATCH FF, *CLOSE C, *COPY CC, *CIRCLE CD, *MATCHPROP D, *DDEDIT DC, *DIMLINEAR DA, *DIMALIGNED DS, *DIMRADIUS DX, *DIMANGULAR QD, *QDIM ZX, *DIMSTYLE DD, *DIST DF, *DIMLFAC 55, *DSETTINGS DT, *DTEXT EC, *ELLIPSE E, *ERASE EE, *EXTEND ER, *externalreferences ER, /*XREF EX, *EXTRUDE H, *HATCH HH, *MLINE VA, *LENGTHEN F, *FILLET J, *JPGOUT 3, *LIST 4, *MOVE VV, *MIRROR MR, *MIRRTEXT AW, *MLEADER AS, *MTEXT Q, *OFFSET ED, *PEDIT 23, *PLOT QW, *PUBLISH WQ, *+PUBLISH P, /*PURGE QQ, *OPEN RD, *RECTANGLE RT, *ROTATE XX, *QUIT RR, *REGEN RV, *REVCLOUD G, *ROTATE AS, *SAVEAS SS, *QSAVE SG, *SPLINE SC, *SCALE S, *STRETCH T2T, *TXT2MTXT TT, *TRIM CS, /*UCS Y, *WBLOCK YY, *BLOCK TS, *LTSCALE V, *PLINE WO, *WIPEOUT Quote Link to comment Share on other sites More sharing options...
Karynlisa99 Posted July 28, 2014 Author Share Posted July 28, 2014 Hi Jaddjax, thank you for taking the time to reply to me. I have found the Manage Tab and the Edit Aliases, however can't figure out how to actually edit the keys. Have tried just changing for example CO - C, -& C - CI, and saving but this doesn't seem to work? What am I missing? thanks Quote Link to comment Share on other sites More sharing options...
CaddJax Posted July 28, 2014 Share Posted July 28, 2014 Then the quick fix for you would be to use the record button, type 'copy' in the command line then stop recording. The next screen that pops up will allow you to edit the details. Type 'c' into the file name and then hit ok. Restart AC and all should be set. Quote Link to comment Share on other sites More sharing options...
Karynlisa99 Posted July 28, 2014 Author Share Posted July 28, 2014 Hi I don't have a record button? Quote Link to comment Share on other sites More sharing options...
CaddJax Posted July 28, 2014 Share Posted July 28, 2014 Also under the manage tab. Quote Link to comment Share on other sites More sharing options...
Karynlisa99 Posted July 28, 2014 Author Share Posted July 28, 2014 The is no record button under the manage tab... even when I type edit alias nothing comes up or type record, nothing comes up... am I going crazy, maybe its the difference between you version and mine? Quote Link to comment Share on other sites More sharing options...
Dadgad Posted July 28, 2014 Share Posted July 28, 2014 In LT you will not find the ALIASEDIT command, because it is an EXPRESS TOOL, likely the same with the RECORD option. On the Tool Bar Menu, down near the bottom you can find Customize > Edit Program Parameters .pgp > click on that and it will tke you to the list of standard autocad shortcalls for commands. Scroll all the way down that list, until you see the section for user customizations, which is what Caddjax is showing you in his post. Make the changes there, not at the top because if you do, they will not migrate at a later date. This area is for personal customizations and it overrides any of the default ones you will see listed above. Be sure to follow the formatting style of the list, and SAVE when you are through, or they will be lost. In Autocad Vanilla we can do it with ALIASEDIT, on the fly, which is nice. I suggest you also make a copy of all your customizations with NOTEPAD copy and paste, and save it somewhere you are confident that it will not be lost. The ribbon image in the snip is from Autocad Vanilla 2013, not sure if it will help you or not. Quote Link to comment Share on other sites More sharing options...
