Retaining Part Colors when changing Assembly Color
I have an assembly made up of several assemblies, one of my parameters is the finish color for the majority of the assembly. So when I select the color in the parameter list, I have iLogic code that changes the color of all the related assemblies using:
Component.Color("Assembly Name:1") = Finish
The problem I'm running into is when this happens all the parts inside the assembly change to that color as well, even though some of those parts have standard colors that should never change (parts from my parts library).
How do I prevent those standard colors on the parts inside the assemblies from changing colors when I want the rest of the assembly to change?
Thanks,
Daniel
