Hi guys i need to rutin that open a file with name test.txt and for each line of this file added
1-find "A" in the file and replace with "AA".
2-added string "xxxxxxxx" in ahead of each line.
3-added "yyyyyy" in the end of each line .
Appriciate for any helping8)
  • Replies 24
  • hosyn
    14
  • hmsilva
    10
  • BIGAL
    1
One way
(setq a (open "X:\\Your\\Path\\test.txt" "r"))
(while (setq b (read-line a))
 (setq c (cons b c))
);; while
(close a)
(foreach x c
 (if (wcmatch x "*A*")
     (setq i 0)
     (while (setq i (vl-string-search "A" x i))
(setq x (vl-string-subst "AA" "A" x i))
(setq i (+ i 2))
     );; while
   );; progn
 );; if
 (setq	x (strcat "xxxxxxxx" x "yyyyyy")
d (cons x d)
 );; setq
);; foreach
(setq a (open "X:\\Your\\Path\\test.txt" "w"))
(foreach x d
 (write-line x a)
);; foreach
(close a)
Hope that helps
Henrique
So thanxxxxx hmsilva
Item 2 ,3 operate okkkkkkkkk , but item 1 don't act well and no change in "A" ,:?
Are you sure?
with
A test e test AA A A
testing B A
Testing A B and C
after running the code
xxxxxxxxAA test e test AAAA AA AAyyyyyy
xxxxxxxxtesting B AAyyyyyy
xxxxxxxxTesting AA B and Cyyyyyy
Henrique
Okey test again and everything is okkkkkkkkkkkkkkkkkk
thanxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx:):D:)
You're welcome, hosyn
Glad I could help
Henrique
And if i have this dos command in bat file ,is there any way for changing to lisp rotine?///?
dir/b/oN/A-H    *.LSP >uu(LSP).LSP
Search here for these two lisp commands Getfiled and Findfile you will find examples to do what you want, as I understand you want .lsp A-H you may need to strip down a list as the two methods I think will give you all but thats easy look at fisrt character of filename.
hmsilva
Everything ok until i wanna change speacial charactor " and parentheses
hmsilva
Everything ok until i wanna change special characters " and parentheses
at this case lisp mismatch:?
(foreach x c
 (setq	x (strcat "[u](load "C:\\000-lisp1\\[/u]" x "[u] " "MyLISP Failed to Load")[/u]")
d (cons x d)
 );; setq
);; foreach
Hi Bigal
I tried following command for dir ::
(command "dir" " C:\\000-lisp--3-1   /b/oN/A-H    *.LSP > C:\\000-lisp--3-1\\uu(LSP).txt")
but didn't operate wello:)
hmsilva
(foreach x c
d (cons x d)
 );; setq
);; foreach
Try
(setq x (strcat "(load " (chr 34) "C:\\000-lisp1\\"  x (chr 34) " " (chr 34) "MyLISP Failed to Load" (chr 34)")")
Henrique
HI BIGAL
I tried this:
(command "dir" " C:\\000-lisp-93-3-1   /b/oN/A-H    *.LSP > C:\\000-lisp-93-3-1\\uu(LSP).txt")
but didnt do well ,any problem in this code??o:)
Try
Henrique
I cheked routine but unfortunatelly didn't do well , and your modification that's mean i must replace internal " with (chr 34)
Try
(setq	x (strcat "(load " (chr 34) "C:/000-lisp1/"  x (chr 34) " " (chr 34) "MyLISP Failed to Load" (chr 34)")")
HTH
Henrique
hmsilva
I tried but had problem still..at this time i divided routin to two separate opretion :
1- i change [color="olive"]"[/color] to www string character .
2-now code change to ::  (setq	x (strcat "(load WWWC:\\000-lisp-93-3-1\\"   x   " WWW WWWMyLISP Failed to LoadWWW)")
3-and operate the fierst lisp
4-the second lisp for replacing  WWW--->> "  and  \ ----->> \\
Now everything ok until item 3 and i need the lisp code for find and replacing www and \ in the file after that running sequential lisp 1 and 2.
Now, I'm getting puzzled...
Can you explain what you're trying to do.
Why you need the WWW and then modify it to " ?
Henrique
BECOUSE OF TRIED:
AND DIDN'T DO WELL.
So for getting modular two task i divide it two section:
1-one lisp for prefix and suffix
2-another one find and replacing
i tried above (withchanging " to www) and everything was ok.
When lisp mismatch with several " i change internal " to www after added prefix and suffix for each line i change back again from www to "
What I was asking was what are you trying to write, a .lsp, or .scr to load all the files in a directory?
a .lsp
Indeed my idea :
i have lisp files in specific directory and every time i added new lisp file for testing to them
i have a bat file for getting the name of these files to one file with :
(command "dir" " /b/oN/A-H    *.LSP >uu(LSP).LSP")
after that with this routine i chang each line to
(load "C:\\lsp--------hlsp\\80----DynOff---DIN OFFSET-----DynOffV2-1.lsp" "MyLISP Failed to Load")
(load "C:\\lsp--------hlsp\\80----trim.lsp" "MyLISP Failed to Load")
(load "C:\\lsp--------hlsp\\80----ctyu.lsp" "MyLISP Failed to Load")
and more file here..........................
and with one command every file embed in the directory load auto to cad:)
are there better way for do this?
