hmsilva Posted July 30, 2014 Posted July 30, 2014 One more question, when you run the dir is not also included the uu(LSP).LSP file? It is in the same directory, truth? Quote
hosyn Posted July 30, 2014 Author Posted July 30, 2014 yes , it is no problem , and can be in root directory and consist of the all of the name lisp file if it is in same directory added 1 line to uu(LSP).LSP for loading itself and i think no problem for loading ,and if mismatching in the load we can embed it another locathion Quote
hmsilva Posted July 30, 2014 Posted July 30, 2014 OK, try (vl-load-com) (if (setq a (vl-directory-files "C:/lsp--------hlsp" "*.lsp")) (progn (setq b (open "C:/lsp--------hlsp/uu(LSP).LSP" "w")) (foreach c a (if (not (wcmatch c "uu(LSP).LSP")) (progn (setq d (strcat "(load " (chr 34) "C:/lsp--------hlsp/" c (chr 34) " " (chr 34) "MyLISP Failed to Load" (chr 34)")")) (write-line d b) );; progn );; if );; foreach (close b) (load "C:/lsp--------hlsp/uu(LSP).LSP" "MyLISP Failed to Load") );; progn );; if HTH Henrique Quote
hosyn Posted July 31, 2014 Author Posted July 31, 2014 wooooooooooooowwwwwwwww:D:) You're Greattttttttttt Lisp programmer I don't know how i can explain thanxxxxxxxxxxx you:lol: Quote
hmsilva Posted August 1, 2014 Posted August 1, 2014 You're welcome, hosyn Glad I could help Henrique Quote
