kizaerf Posted July 30, 2014 Share Posted July 30, 2014 Is there a way to set a 'snap hierarchy' for example, I want the 'perpendicular' snap to snap before the 'nearest' since it's more accurate. I would rather 'nearest' be the last resort snap if nothing else. thanks, Quote Link to comment Share on other sites More sharing options...
rkent Posted July 30, 2014 Share Posted July 30, 2014 No hierarchy. Don't use nearest, problem solved. Quote Link to comment Share on other sites More sharing options...
zaphod Posted July 30, 2014 Share Posted July 30, 2014 I normally only use 4 object snaps; endpoint, center, midpoint, and intersection. For any other snap I need, I shift and right click during the command and pick the next needed snap. Quote Link to comment Share on other sites More sharing options...
kizaerf Posted July 30, 2014 Author Share Posted July 30, 2014 If i didn't need nearest sometimes I wouldn't use it rkent. thanks though. I think I am going to stick with the shift right click Zaphod - that solves it. Didn't know that was a thing. Quote Link to comment Share on other sites More sharing options...
rkent Posted July 30, 2014 Share Posted July 30, 2014 I use the F keys for my osnap needs, hitting the one needed at the time. Like F2 for perp or F3 for nearest, this way you are certain that your pick is right where you want it. With running osnap you can pick in space and it will still make a pick, setting the osnap each time ensures that a pick in space will not result in a pick, instead you will see that it did not select anything and you have to go again. Quote Link to comment Share on other sites More sharing options...
