Text Justification Setting to Palette
nicolas
Dear All,
I am looking for a way to add justification to a newly created text palette. I have a mtext set to the correct layer, color and size and justification. I dragged it to the tool palette and everything works well except for the text justification. I have checked the properties on the palette but no solution here. Is there a way to add a system variable to
^C^C_mtext
Your help would be very valuable. Thanks.
Hi,
I have found the solution. In the palette, need to insert the following command:
^C^C_textsize;1.65;mtext;\j;MC
Thanks.
