I'm assuming this is a beginner's question, so here goes. I've done a few searches with different keywords and didn't find it- apologies if it's been answered before.
Occasionally settings just change, for no apparent reason. The most recent was the boss losing his open dialog box this morning. Thanks to the forums here, that's fixed. For the majority of my 2 1/2 years working on ACAD 2002 on this system, I've had the ability to drag and drop MTEXT items. No need to grab the anchor, just click on it to select, wait a split second, drag to new location. For some reason I can no longer do that. It shows me a little box on the cursor as I drag, but no dice- and I swear I can hear it chuckling at my frustration. :x Can anyone share what setting it is that got tripped, and how to get it back? Thanks!
ETA: The same is now true for Ctrl+Dragging to copy the items.
Think the old PICKFIRST has risen his ugly head again my friend... set to 1 and all will be well again. :-)
I just tried it and it cackled. Like a madman. (Translation: it was already set to 1, so I toggled and tested, then toggled back and retested, no drag.) Is there anything else it could be?
I'm taking a stab in the dark here - have you changed mouse recently? we've had problems here before that has more to do with the mouse own settings than with AutoCad
It was set to 2 (auto). Other values didn't work. Same mouse.
If nothing else, with your help I'm learning quite a bit. ;)
There's the silver lining :)
and I have learnt that I can drag-n-drop text! that's the annoying thing, it works on ym computer (althouhg I had no idea until now) and I have no idea where it comes from....
Is the text on a layer that's locked by any chance?
This may sound really bad, but are you sure its MTEXT and not an attribute or something along those lines?
