michaeloureiro Posted December 10, 2008 Posted December 10, 2008 is there an easy way to eliminate images from a dwg file, in other words, detach images that aren´t being used? thanks Quote
skipsophrenic Posted December 10, 2008 Posted December 10, 2008 type in XREF or IMAGE in the command bar (both do the same thing) then select the image in the drop down list and right click on it and click detach. Quote
michaeloureiro Posted December 10, 2008 Author Posted December 10, 2008 thanks skipsophrenic, simple enough:) Quote
