kizaerf
OVERKILL command arbitrarily decides to work (mostly doesn't)
kizaerf
usually it works like a charm but sometimes it plain does nothing. like in this example, there are two overlapping white lines. I do the overkill command and set a high tolerance, but it doesn't do anything. See pictures. why does it work sometimes and then other times it completely does nothing?
Share this post
Link to post
Dana W
The line properties don't match exactly in one or more of the properties you are NOT ignoring.
Share this post
Link to post
kizaerf
even with all the options checked, it still doesn't work.
Share this post
Link to post
nukecad
You seem to be in 2D there.
Are your overlaid lines co-planar, (same Z value)?
Share this post
Link to post
Dana W
+1 to that ^^^^.
Share this post
Link to post
SLW210
Post a drawing that OVERKILL is not working, if possible.
Share this post
Link to post
zaphod
try changing your tolerance from 1.000000 to 0.000001
Share this post
Link to post
kizaerf
I am going to try all these great suggestions! thank you.
Share this post
Link to post
