Hi guys
Some times, there are some lisp code can't run on "UCS Mode" ,Only On "WCS",
How to do?
I think, maybe add "restore to WCS" at the beginning .
I need some code . help!
(defun c:foo ( / vars... )
 (command "_.ucs" "_w")
 (etc...)
 (command "_.ucs" "_p")
 (etc...)
Marko.Thank you!
When error ,how "(command "_.ucs" "_p")" ?o:)
Add:
To the *error* function (if present), else define your own local *error* function containing this expression.
More information on how to define an *error* function can be found here.
How add:
to this function ?
(defun c:test ( / *error* osm )
   (defun *error* ( msg )
       (if osm (setvar 'osmode osm))
       (if (not (member msg '("Function cancelled" "quit / exit abort")))
   (setq osm (getvar 'osmode))
   (setvar 'osmode 0)
   (rtos (getreal "\nPress Esc to exit, press Enter to force an error ..."))
       (if (= (getvar 'worlducs) 1) (command "_.ucs" "_p"))
   (setvar 'osmode 0)
   (*error* nil)
