BIGAL Posted September 16, 2014 Share Posted September 16, 2014 Perhaps another approach guys due to some little things not quite right. Enter the full path name of the block as text picking a pt on the drawing this could be achieved using a simple temporary grid text at lower left grid pt. Then just ssget the text and do insert of the block named in text. This way if you dont like the order 3x2 can easily change to 2x3 3x3 do again etc two seperate defuns one for findfile&text 2nd for insert. I use this method to insert staff images on building floor plans some 200+ images. Order of picking does not count. Quote Link to comment Share on other sites More sharing options...
Tharwat Posted September 16, 2014 Share Posted September 16, 2014 Tharwat I can not understand this !!! Go to Tools in the menu bar then Palettes then Design Center , so this would prompt you a dialog that you can search for your drawings then you can select the drawing you want and throw it into current opened drawing . After that we can write a program that can rearrange them in columns as best as you want . Tharwat Is it possible to add GetFolder in your code ? It is but it needs too much codes with a dialog box to allow you to select folders , one by one then add the included drawings within into a list with an option also to delete the unneeded drawings to be inserted into the target drawing . Quote Link to comment Share on other sites More sharing options...
Guest Posted September 16, 2014 Share Posted September 16, 2014 write a program that can rearrange them in columns as best as you want It is but it needs too much codes with a dialog box to allow you to select folders , one by one then add the included drawings within into a list with an option also to delete the unneeded drawings to be inserted into the target drawing . hi Tharwat . I understand the difficulty, but when you find time please try to modify the code .. Thanks Quote Link to comment Share on other sites More sharing options...
Guest Posted September 17, 2014 Share Posted September 17, 2014 Any other ideas ? Quote Link to comment Share on other sites More sharing options...
Guest Posted September 18, 2014 Share Posted September 18, 2014 this is exactly what i have in my mind Maximun lines = 6 Colums = no limit All sections arrange by name example : d1,d2,d3,..........,d9,d10,.....,d19,d20,...... Look the attach file test.dwg Quote Link to comment Share on other sites More sharing options...
highflybird Posted September 19, 2014 Share Posted September 19, 2014 this is exactly what i have in my mindMaximun lines = 6 Colums = no limit All sections arrange by name example : d1,d2,d3,..........,d9,d10,.....,d19,d20,...... Look the attach file I found your question much more special ! so many! so many! Quote Link to comment Share on other sites More sharing options...
Guest Posted September 19, 2014 Share Posted September 19, 2014 I found your question much more special ! so many! so many! Hi highflybird .I know , but is a very useful lisp Can any one help Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 20, 2014 Share Posted September 20, 2014 I think were at that point where some of us have supplied answers and it just does not quite meet your requirements, at some point it is your turn to have a go, we walk away, looking at your number of posts you have been using Cadtutor for a while so should understand this is not a never ending free support service. I stick by my proposal its simple and I know it works. Quote Link to comment Share on other sites More sharing options...
Guest Posted September 22, 2014 Share Posted September 22, 2014 I think were at that point where some of us have supplied answers and it just does not quite meet your requirements, at some point it is your turn to have a go, we walk away, looking at your number of posts you have been using Cadtutor for a while so should understand this is not a never ending free support service. I stick by my proposal its simple and I know it works. you judged me very badly Quote Link to comment Share on other sites More sharing options...
Guest Posted September 25, 2014 Share Posted September 25, 2014 this is exactly what i have in my mindMaximun lines = 6 Colums = no limit All sections arrange by name example : d1,d2,d3,..........,d9,d10,.....,d19,d20,...... Look the attach file is it possible to insert all sections from a path list and arrange all sections by name (like the list? ) path_list.txt Quote Link to comment Share on other sites More sharing options...
Saleej KT Posted November 26, 2020 Share Posted November 26, 2020 http://ktsaleej.blogspot.com/2017/09/insert-multiple-drawing-files-dwg-or.html Insert multiple drawing files ( .dwg or .dxf ) to an AutoCAD sheet In above my blog will help you to generate AutoLISP(.lsp) program to insert multiple drawing files ( .dwg or .dxf ) to an AutoCAD sheet. Just fill a form and generate your AutoLISP(.lsp) program to insert multiple drawing files. Quote Link to comment Share on other sites More sharing options...
CADTutor Posted November 29, 2020 Share Posted November 29, 2020 Hi @Saleej KT if you would like to provide access to your routine from this forum, you can always add it to the Download section. Quote Link to comment Share on other sites More sharing options...
