jonathantimms Posted December 11, 2008 Share Posted December 11, 2008 Since signing up to this forum, i hear a lot about blocks and bedit, can some one fill me in as to what this is, how its used, and what its useful for? I know there are sure to be loads of things i have no idea what they are or how they are used, but this one seems rather commonly used. Quote Link to comment Share on other sites More sharing options...
MaxwellEdison Posted December 11, 2008 Share Posted December 11, 2008 From the AutoCAD help file: A block is one or more objects combined to create a single object. Blocks help you reuse objects in the same drawing or in other drawings. The Block Editor is a separate environment for creating and changing block definitions for the current drawing. You can also use it to add dynamic behavior to blocks. I recommend you read over the help files provided with autocad first, also check out some online tutorials like this one:http://www.autocadcentral.com/Tutorials/Lesson%2012/lesson12.htm Quote Link to comment Share on other sites More sharing options...
