jasmin_cad Posted October 21, 2014 Posted October 21, 2014 Please see the attachment,I'm trying to smooth the joint btw these two 3d objects,when I use the smooth command its smooth all the object which I dont want,I want to smooth just the joint line in the corner.I hope I explained correctly Thanks for your help cad toutr.pdf Quote
nestly Posted October 21, 2014 Posted October 21, 2014 Welcome to Cadtutor Assuming the objects are a single Solid, have you tried FILLET command? Watch the command line or Dynamic Input prompts for a "Loop" option to make sure it fillets the whole way around. Quote
jasmin_cad Posted October 21, 2014 Author Posted October 21, 2014 Thank you nestly for your respond,I tried but didnt work.The objects two single solid and i made them one object by union command. Quote
zaphod Posted October 21, 2014 Posted October 21, 2014 the "objects" look like surfaces to me, attach a DWG file and I'll take a look at it Quote
jasmin_cad Posted October 21, 2014 Author Posted October 21, 2014 Thanks, her's the cad file cad.dwg Quote
ReMark Posted October 21, 2014 Posted October 21, 2014 (edited) One object is comprised of both a surface and a mesh. The other is a solid. Edited October 21, 2014 by ReMark corrected my observation Quote
jasmin_cad Posted October 21, 2014 Author Posted October 21, 2014 So,how i can make it both solid?also do you think that's why the connection is not smoothing? Quote
ReMark Posted October 21, 2014 Posted October 21, 2014 OK...I was able to apply a fillet to the area (seam?) where the vertical and horizontal objects meet. What program was used to create the original objects? Quote
jasmin_cad Posted October 21, 2014 Author Posted October 21, 2014 ReMark,they should meet at the conncection line which is showing @ the drawing Quote
ReMark Posted October 21, 2014 Posted October 21, 2014 That's the point at which I created the fillet. Your geometry isn't consistent so the result of the fillet won't be either. Quote
jasmin_cad Posted October 21, 2014 Author Posted October 21, 2014 I created the objects @autocad 2013,The area you showing in red is the connection line Quote
jasmin_cad Posted October 21, 2014 Author Posted October 21, 2014 how can i make it consistent?sorry I'm new to 3d cad Quote
ReMark Posted October 21, 2014 Posted October 21, 2014 If you want the fillet to be consistent then I think the left hand end of the horizontal piece would have to be circular. I'm guessing here. What is the object supposed to be? BTW...the object has been drawn using decimal inches. Is that what you had intended? Quote
jasmin_cad Posted October 21, 2014 Author Posted October 21, 2014 This was my reference to create the 3d model.to many thanks for your time and help:) Model (1).pdf Quote
ReMark Posted October 21, 2014 Posted October 21, 2014 I'm afraid to ask but here goes anyway. What the hell is it? Too high for a urinal. The connection going into the wall, is it supposed to be a pipe? Quote
jasmin_cad Posted October 21, 2014 Author Posted October 21, 2014 It's a FRP drums shape for decorative Quote
ReMark Posted October 21, 2014 Posted October 21, 2014 So this "drum" has a connection that goes through the wall for transmitting sound to the other side? This connection will be somewhat "freeform"? Quote
jasmin_cad Posted October 21, 2014 Author Posted October 21, 2014 Please see the attachment,you will understand how its work:) 76.pdf Quote
ReMark Posted October 21, 2014 Posted October 21, 2014 Other than the drum shape itself the "connections" all appear to be different from each other. I don't see any need therefore to refine the connection between the two pieces. Fillet as you deem fit and move on from there. Quote
