Change default settings of Revit
Hi all,
It makes me sick that, everytime when i open a project, that i have to thick the box 'multiple' when i want to copy something.
Still haven't found the solution to change it, so that it will be on by default.
Can't find it in the ini-file...
Also some other settings i would like to change but the 'multiple copy' part annoys me the most...
Please help me make my life easier...
Thnx
Wesley
There is no "ini" file, but there is a Keyboard Shortcuts menu. Type KS or go to the "R" Application Button > Options > User Interface > Keyboard Shortcuts.
There's not a dedicated Copy Multiple tool. But all you have to do is check the box the first time Copy is used per session in Revit and it stays until you uncheck it. Problem solved. :)
Hitzframpton,
I know i have to check that box, but it surprizes me that i have to do that every single day.
Why is it, that with Autocad you can customize every single option for the most simple things.
But Revit won't let you.
There must be a workaround!:danger:
You've got to let go of comparing AutoCAD to Revit. They are totally different from the ground up and even AutoCAD can't do things that seem simple. I'm not sure if you can change the default setting for that box but it is only a quick click of the mouse.
Is it really that annoying to you?
Well, not really annoying, but i just can't believe that it can not be changed...
There might be a registry key somewhere for it, I haven't looked but a lot of those type of things are saved as registry keys.
