AIberto Posted October 26, 2014 Share Posted October 26, 2014 Source from : bbs.xdcad.org , by st788796 (defun XD::AutoStartup (path tf / Profiles allpro newnum AutoLoadpath) (vl-load-com) (if tf (progn (vla-getallprofilenames (vla-get-profiles (vla-get-preferences (vlax-get-acad-object)) ) 'Profiles ) (setq allpro (safearray-value Profiles)) ) (setq allpro (list (getvar "cprofile"))) ) (setenv "ACAD" (strcat (getenv "ACAD") ";" (vl-filename-directory path)) ) (if (wcmatch (getvar "acadver") "19.[1-9]*") (if tf (mapcar '(lambda (x / trpath) (setq trpath (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" x "\\Variables" ) ) (vl-registry-write trpath "Trustedpaths" (strcat (vl-registry-read trpath "Trustedpaths") ";" (vl-filename-directory path) "\\..." ) ) ) allpro ) (setvar "TRUSTEDPATHS" (strcat (getvar "TRUSTEDPATHS") ";" (vl-filename-directory path) "\\..." ) ) ) ) (mapcar '(lambda (x) (setq AppLoadPath (strcat "HKEY_CURRENT_USER\\" (vlax-product-key) "\\Profiles\\" x "\\Dialogs\\Appload\\Startup" ) ) (setq NewNum (itoa (1+ (read (vl-registry-read AppLoadPath "NumStartup") ) ) ) ) (vl-registry-write AppLoadPath "NumStartup" NewNum) (vl-registry-write AppLoadPath (strcat NewNum "Startup") path ) ) allpro ) (princ) ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted October 26, 2014 Share Posted October 26, 2014 Huh ? we share our autostart its on a network no need for lisp. Quote Link to comment Share on other sites More sharing options...
