ADT2k4 - Odd selection problem
Chochem
I have no idea which key I hit but for some reason I can't pre-select items then use a command on them.
For example, if I have a line selected and I type the move command it de-selects the line and I have to then re-select the line with the move command active.
It has also made it so hitting the delete key doesn't delete anything. I have to type 'erase' then select to delete things.
