Hello,
I would like to prepare kind of "Final Setup" program. Something that would cleanup the drawing and set layouts for printing. I am wondering if somebody could help me with this. This is pretty simple but I cant get it working.. (I am no programmer of any kind)
I prepared rough lisp working (attached).
I would like to be able use toggles to decite which function will be activated (Audit, purge, overkill, layout setup).
I would also like it to be in one file, without separate .dcl file.
Partial dcl. file attached.
Thank you in advance.
Regards.
FinalSetupTool.lsp
FinalSetup.dcl
Well, if you're using LISP, you're relegated to using a separate .DCL file AFAIK... Perhaps compiling to .FAS or .VLX resolves this? *not sure*
As for setting the layouts, look for one of my posts that includes a link and an example code snippet with vla-SetActivePageSetup function.
Cheers
The dcl is not being used ? You can certainly add a Do you want To ? as steps in the program make the which is Nil as answer to a Getstring to keep going I would put qsave last rather than do for each layout each time.
(setq ans (Getstring "\nDo Purge for yes press <Cr> or any key for No"))
(if (= ans nil)
(Command "-purge" "a" "n")
Thanks for your reply. I'll keep working on this one. It's pretty hard to convince people to keep drawing in order..
Auto Reg. purge by BlackBox seems usefull. I'll be using it.
Cheers
The key is to *try* and make it easier for user(s) to adhere to the standard, than to do their own thing... Event-driven tools like the one linked above have greatly helped here.
I'm flattered that you find AutoPurgeReg useful. :)
Cheers
Just and update.
Apparently someboty else thought about same stuff some time ago. (Lisp attached).
This is for page setup only. I would add drawing frame block insertion and also cleanup tools. If somebody knows how do do it, this would be nice, at this moment the code is to much for me.
I have also found BlackBox App (also attached) but I cant get it running. I have ACad 2015.
Cheers
LayoutTools.dcl
LayoutTools.lsp
bbox_AcPageSetup.bundle.zip
Just and update.
Cheers
Rather than posting my app, please provide a link to where you found it, as that post included a great deal of related information and even sample code.
Cheers
Cheers
Could you please provide us with the link?
Yes, I think that's where I found it.
Cheers
