I am struggling over combining 2 different lists. Elements from list 1 contains, lets say, 1 2 3, while elements from list 2 are A B C D. The master list would look something like this:
1 A
1 B
1 C
1 D
2 A
2 B
2 C
And so on. I think I need to use the FOREACH function, but just not sure. Any help would be great.
You can use nth to get each individual value and then say Strcat to make the new value.
(setq list1 (list 1 2 3 4 5 6 7))
(setq list2 (list "a" "b" "c" "d" "e" "f" "g"))
(setq len (length list1)) ; I would check here that list1 is same number as list2
(setq x 0)
(repeat len
(Princ (strcat "\n" (rtos (nth x list1) 2 0) " " (nth x list2)))
(setq x (+ x 1))
Not sure I understand the desired output, so here are two adaptations:
(mapcar
 (function
   (lambda (x y) (cons x y))
 '(1 1 1 1 2 2 2)
 '("A" "B" "C" "D" "A" "B" "C")
(mapcar
 (function
   (lambda (x y) (list x y))
 '(1 1 1 1 2 2 2)
More information is needed.
RANGE_LIST = [["RANGE 1" 1.0 ] ["RANGE 2" 2.0 ] ["RANGE 3" 3.0 ] ["RANGE 4" 4.0 ] ["RANGE 5" 5.0 ]]
PART_SIZE_LIST = [["AC" 0.1] ["PVC" 0.5]]
End result would be a list that would look like this:
MASTER_LIST = [["AC" 0.1 "RANGE 1" 1.0 ] ["AC" 0.1 "RANGE 2" 2.0 ].......
Basically I want to add each element of the range_list to each element of the part_size_list to create a brand new element in the master_list.
Try this it is a variation on using nth
(setq x 0)
(setq Y (- (Getint "\nEnter item Number from list2") 1))
(repeat len
(Princ (strcat "\n"  (rtos (nth x list1)2  0) " " (nth Y list2))) ; dont need rtos if strings
(setq x (+ x 1))
Something like this, perhaps...
(setq a '(("RANGE 1" 1.0)("RANGE 2" 2.0)("RANGE 3" 3.0)("RANGE 4" 4.0)("RANGE 5" 5.0))
     b '(("AC" 0.1) ("PVC" 0.5))
(foreach x b
 (setq n -1)
 (while (setq y (nth (setq n (1+ n)) a))
   (setq c (cons (append x y) c))
(setq c (reverse c))
Henrique
Maybe:
(mapcar '(lambda ( x ) (mapcar '(lambda ( y ) (append x y)) a)) b)
Or, if a single list is required:
(apply 'append (mapcar '(lambda ( x ) (mapcar '(lambda ( y ) (append x y)) a)) b))
Nicely done. :)
Henrique
Maybe:
Lee as always you are brilliant, works just as I need it to, for the most part, just have to reverse a few things. But perfect! Thank you very much!
Thank you for your flattering comments JSYoung, I'm happy to help :)
No problem, I am sure I am going to need a bit more help by the time I am done this LISP. The entire idea behind this LISP is to be able to have a complete pipe depth list, sorted by ranges and different types of pipe used.
