hcostanzo Posted December 31, 2014 Share Posted December 31, 2014 I've created a dashed Linetype for road stripping. Is there a way to set either the code for the Linetype or some setting in the drawing that will keep the dashes from stretching out? I need the dashes and the gaps to be exact lengths. Code: *10FTLINE25FTGAP A,.5,-1.25 Thanks in advance Quote Link to comment Share on other sites More sharing options...
ReMark Posted December 31, 2014 Share Posted December 31, 2014 Wouldn't that be controlled by the linetype scale factor found on the Properties palette? Quote Link to comment Share on other sites More sharing options...
nestly Posted December 31, 2014 Share Posted December 31, 2014 By default, linetypes are scaled according to the Annotation Scale. If you want the pen-up and pen-down length in the linetype definition to remain constant regardless of the scale in Modelspace, change MSLTSCALE = 0. In Paperspace/Layout, change PSLTSCALE = 0 (REGEN may be necessary to update the line scaling) Quote Link to comment Share on other sites More sharing options...
hcostanzo Posted December 31, 2014 Author Share Posted December 31, 2014 Thank you, that fixed the problem! Quote Link to comment Share on other sites More sharing options...
