HELP:LISP to change color of text base on certain words including within nested block
vernonlee
Have tested it
1) if keyed in word is the first word of the sentence, it will be selected if not it would be selected
Also,can mtext be part of the standalone text to be selected as i have a mix of text & mtext in my working dawings.
Thanks
Edited by vernonlee
  • Replies 22
  • vernonlee
    12
  • Tharwat
    7
  • BIGAL
    2
  • ttray33y
    1
Posted Images
Hi Tharwat, any updates to the lisp routine?
Thanks
Have tested it
Thanks
  • 6 years later...
Thank you TARAVWAT with amazing codes about this post.i checked your code and i had following error
may you correct issue💫
offcors apperantly one last parantesses missed and i added in the bottom but nothing to do
