Ravenstown Posted January 30, 2015 Posted January 30, 2015 In MEP 2013 if you right click (in model space) to bring up the "general panel" and select "isolate", you have 6 options, i.e. edit in section, edit in plan, edit in elevation, isolate objects, hide objects, end object isolation. In MEP 2014 the edit in section, edit in plan, edit in elevation options do not show up although the help section says they should be there. Do I need to install or enable extra tools or change an environment or setting to get the options to appear again? Quote
