ENTSEL to cycle through selection set...
Hi guys,
I'm not even sure I am going about this the right way, but let me try to explain what I'm trying to achieve, and the method I am trying to achieve it.
I have a ProSteel command (PS_CREATE_SPEZPART) that I would like to pass each element of a selection set to - one by one. From what I understand, this ProSteel command will accept selections in the form of ENTSEL, but not single item selection sets.
So I had a thought to create a selection set, and cycle through it using the REPEAT & SSNAME functions.
(defun c:tmi ()
(prompt "\nSelect item:")
(setq ss (ssget))
(setq num (sslength ss))
(setq con 0)
(repeat num
(setq ent3A (ssname ss con))
(command "PS_CREATE_SPEZPART" ent3A nil)
(setq con (1+ con))
... which does not work.
I think what I am struggling with is... SSNAME returns the name of an entity - rather than selects that entity. Is this correct or am I missing something?
So my question is, is it possible to pass each element to this ProSteel command, in the same manner as ENTSEL would?
Thanks a lot for any help.
Since entsel returns a list of two items (the selected entity and the center of the cursor pickbox), try something like the following:
(defun c:tmi ( / num sel )
   (prompt "\nSelect item: ")
   (if (setq sel (ssget))
       (repeat (setq num (sslength sel))
           (command "_.PS_CREATE_SPEZPART"
               (list (ssname sel (setq num (1- num))) '(0 0 0))
Depending on how the command operates, the point supplied with the entity may need to be located on or near to the object.
Hi Lee and BigAl,
Thanks a lot for your help. You have, once again, nailed it.
Lee - your routine works great, I have tested it on a few types and combinations of elements, and it has worked every time. To further my education though, could you please explain the logic/philosophy behind the "(1- num)". I understand it is being used to work through the selection set (being the index for SSNAME). I just can't get my head around "1-"... is it the same as "num - 1" (but in the correct syntax)?
Haha, BigAl - Lee sure is quick, thanks for your suggestion.
It's not actually Lee, he set up a lisp routine to answer questions for him.
Excellent to hear! Thank you lamensterms :)
Exactly -
The 1- & 1+ functions are just convenient & quick functions which simply increment or decrement a given numerical value by one:
(1+ x) is the same as (+ x 1)
(1- x) is the same as (- x 1)
Therefore, my code is iterating over the selection set starting with the entity at the (sslength-1)th position and decrementing the index to zero (since selection set indexes are zero-based). For more information on this topic, you might find my tutorial on Selection Set Processing of interest.
:lol: :lol: What can I say, LISP was originally intended for developing A.I. ;)
Awesome, thanks a lot for taking the time to explain, Lee.
You're welcome lamensterms! -
Feel free to ask if you have any further questions.
Lee
