Rhayes
Att. Tag information
We have a number of Different door widths in regards to egress and I have a typical egress tag that
Gives the door width and the occupancy number. My question is can you add a formula to a block att. That I can key in the door width and have the occ load number input Automaticlly.???
Share this post
Link to post
Have you thought of using a dynamic block with visibility states for each door size? or....
If you use a lisp routine to insert the block, you could prompt for the door width (attribute 1), and use a formula to determine the occupancy number and use that as the value for the 2nd attribute.
Share this post
Link to post
A lisp routine would be nice. I do not have one that inserts a block.
Do you know where i could find a lisp routine that would do that.???
Share this post
Link to post
Ok, I notice from your blocks there are 3 attributes each
1. stair block- do you want 2 prompts, ST-X and width?
is the occupancy always the width / .2?
do you need "width/.2" displayed or just the width?
do you need "OCC" tagged on at the end in the third attribute?
2. door block - same questions
is the occupancy always the width / .15?
Share this post
Link to post
1. stair block- do you want 2 prompts, ST-X and width? -YES
is the occupancy always the width / .2? - YES
do you need "width/.2" displayed or just the width? "Width/.2
do you need "OCC" tagged on at the end in the third attribute? Yes
is the occupancy always the width / .15? YesToday 03:23 pm
Share this post
Link to post
Thanks lpseifert, that was Awesome.
they work great.
I have a question.? If I want to change the top line of the
block to Read "4 Doors @ 33" Then the second line would be
(4x33) and read "132" /.15" and then the bottom would remain
the same as 880 OCC.
Can I add a line in the lisp that would take the Number of doors
x the actual width and then take that number and / by .15 for
the total Occupancy load.???
Share this post
Link to post
You'd need to create a prompt for # doors
use strcat to create variable for attribute #1
edit variable for attribute #2
no time now maybe later, if you'd like.
BTW, what do you mean by 'that was assume'?
Share this post
Link to post
Sorry I have another Dumb Question.?
If the block does not reside in the drawing the lisp does not work.
Is there a way to insert the block if it is not in the drawing.???
Am I getting way to complacated.???
Share this post
Link to post
here's one way
(if
   (not
     (tblsearch "block" "BLOCKNAME"))
   (command "-insert" "BLOCKNAME" (command))
the path of the block will need to be hard coded if it isn't in acad's search path.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
