ILoveMadoka Posted February 18, 2015 Share Posted February 18, 2015 For some reason the Express Tools were not loaded when they installed Autocad 2015. I guess the checkbox was overlooked among the tons of other stuff loaded. In days of old you could copy the Express Tools folder, load the Express Tools Menu and "APPLOAD" the main file and you were good to go. I found the Express folder among the install files (they're not compressed) But when I go to load the menu, I don't see it. Can anyone walk me through the process of manually loading the Express Tools in Autocad 2015 (Please??) Thanks Much!! Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted February 18, 2015 Author Share Posted February 18, 2015 I did find the "acetmain.cuix" menu file among the setup files and have loaded it. The Express Tools is now showing up in my menu. What file do I "APPLOAD" to get the Tools to work? Thanks.. Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 18, 2015 Share Posted February 18, 2015 Are you saying that if your were to click on the ARCTEXT express tool AutoCAD returns "unknown command"? Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted February 18, 2015 Author Share Posted February 18, 2015 Yes Sir... Command: txt2mtxt Unknown command "TXT2MTXT". Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 18, 2015 Share Posted February 18, 2015 Did you include the path to the folder in your Support File Search Path under Options > Files? Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted February 18, 2015 Author Share Posted February 18, 2015 Yes Sir. Restarted ACAD and verified the path is there.. I have also loaded acettest.fas and acetutil.fas (which I thought made everything go)... Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted February 18, 2015 Author Share Posted February 18, 2015 To add to the mystery... Some items are now working. Autonumber (tcount), Enclose in object (tcircle), Superhatch, Text Case (tcase) all work Move/Copy/Rotate (mocoro), Convert to MTEXT (txt2mtxt) still not working... Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 18, 2015 Share Posted February 18, 2015 Maybe you didn't get everything you thought you did. Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted February 18, 2015 Author Share Posted February 18, 2015 I just copied the entire folder... are there express files "elsewhere?" Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted February 18, 2015 Author Share Posted February 18, 2015 That's why I asking for help here... Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted February 18, 2015 Author Share Posted February 18, 2015 You want something bad enough, you figure it out... Talk about weird $%&%! Here is the mystery file: leaderex.arx Load that and TXT2MTXT works... :-| Quote Link to comment Share on other sites More sharing options...
ReMark Posted February 18, 2015 Share Posted February 18, 2015 I'm not sure why you took the approach that you did. Most users will install Express Tools right from the installation DVD, even after the fact, rather than copy a folder and try to install manually. Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted February 18, 2015 Author Share Posted February 18, 2015 Where I work, someone else does the installing and trying to get something fixed... may take several days. Self-help gets things done much faster.. Perfect world, I get to install myself and have complete control. I don't work in that world.. If some of my applications didn't require Admin privileges, I probably couldn't have done what I did to get it working.. You can't copy files into any folders under \Program Files or under the \Root as a USER. You can't even delete shortcuts off your desktop. Locked down.. That's my world.. ps: To get Move/Copy/Rotate to work, load: mocoro.arx Google.. I just tend to come here first. Quote Link to comment Share on other sites More sharing options...
ILoveMadoka Posted February 18, 2015 Author Share Posted February 18, 2015 I do appreciate the assistance.. (and for past help too!) Quote Link to comment Share on other sites More sharing options...
