kzoppo Posted March 20, 2015 Posted March 20, 2015 Going away from the block problem a moment there are numerous ways of selecting visually a block and inserting and having it auto roatte and malign properly. 1st step picking block if you look at tool paletes they have a little picture and can have sub lists etc, you can create your own toolbar and insert correct block, you can have a menu with your block names agian with cascading sub menus very very easy. Old fashoined is using a menu and slides to visually pick your block. Lastly simple lisp to do all the aligning the code is hidden behind the menu or palette, so for me pick block pick line all done. [ATTACH=CONFIG]53374[/ATTACH][ATTACH=CONFIG]53375[/ATTACH] Hi Bigal, I am using tool palettes and trying to use the auto rotate when placed. I'm not really sure what you're trying to suggest though. Quote
