karim-salem Posted March 2, 2015 Share Posted March 2, 2015 hi, I have a little problem with a lisp file that extract coordinates from DWG and label them with prefix and counters then export them to text file. if anybody can advice how to exit this lisp correctly i would really appreciate it a lot. (defun run () (setq pll (getstring "\nPlease Enter of new file (name.ext) :")) (setq pl (open pll "w")) (setq ang ( getreal "\nPlease Enter DV Angle: " ) ) (setq n ( getstring "\nPlease Enter TAXI name: " ) ) (initget (+ 1 2 4)) (setq a ( getint "\nPlease Enter MH number: " ) ) ;(setq e (getstring "\nget no. of first Point :")) ;(setq a (atoi e)) (while (> a 0) (setq aa 1) (while (<= aa 4) (setq p (getpoint "\nselect point :")) (setq v1 (strcat "\n " (itoa a) " " (itoa aa) " ")) (setq d (polar p (dtr 90) 0)) (setq f (itoa aa)) (setq k (itoa a)) (setq g (strcat n "-" k "-P-" f)) (command "layer" "m" "number" "c" "3" "" "") (command "text" "m" d 0.2 ang g) (setq num (entlast)) ;(command "change" num "" "layer" "" number "") (command "change" num "" "p" "layer" "number" "") (command "layer" "m" "point" "c" "1" "" "") (command "point" p) (setq pt (entlast)) ;(command "change" pt "" layer "" point "") (command "change" pt "" "p" "layer" "point" "") (setq x (car p)) (setq x (rtos x 2 4)) (setq x (strcat x " ")) (setq v2 x) (setq y (cadr p)) (setq y (rtos y 2 4)) (setq y (strcat y " ")) (setq v3 y) (princ V1 pl) (princ v2 pl) (princ v3 pl) (setq aa (+ aa 1)) ) (setq a (+ a 1)) ) (command "layer" "m" "txt" "c" "5" "" "") (close pl) (redraw) (princ) ) (defun c:I () (run) (setq fil (getstring "\nget name of the file (name.ext) :")) (setq p1 (getpoint "select insertion point :")) (setq p2 (polar p1 0.0 35.0)) (setq p3 (polar p1 0.0 105.0)) (setq p4 (polar p1 (/ (* -1 pi) 2) 20.0)) (setq p5 (polar p4 0.0 35.0)) (setq p6 (polar p4 0.0 70.0)) (setq p7 (polar p4 0.0 105.0)) (setq p8 (polar p2 (/ (* -1 pi) 2) 10.0)) (setq p9 (polar p8 0.0 35.0)) (setq p10 (polar p8 0.0 70.0)) (setq p11 (polar p8 (* -1 pi) 15.0)) (setq p12 (polar p8 (/ pi 2) 5.0)) (setq p13 (polar p8 (/ (* -1 pi) 2) 5.0)) (setq p14 (polar p12 0.0 35.0)) (setq p15 (polar p13 0.0 17.5)) (setq p16 (polar p13 0.0 52.5)) (setq p1- (polar p1 (/ (* -1 pi) 2) 2000000000.0)) (command "text" "m" p11 3.0 0.0 "POINT NO.") (command "text" "m" p14 3.0 0.0 "COORDINATES") (command "text" "m" p15 3.0 0.0 "X") (command "text" "m" p16 3.0 0.0 "Y") (command "line" p1 p4 "") (setq L14 (entlast)) (command "line" p2 p8 p5 "") (setq L285 (entlast)) (command "line" p9 p6 "") (setq L96 (entlast)) (command "line" p3 p10 p7 "") (setq L3107 (entlast)) (command "line" p1 p2 p3 "") (command "line" p8 p9 p10 "") (command "pline" p4 p5 p6 p7 "") (setq L4567 (entlast)) (setq fill (open fil "r")) (read-line fill) (setq new ()) (setq j 0.0) (setq p44 p4) (while (setq S (read-line fill)) (setq pt (polar p44 (/ (* -1 pi) 2) (+ 5 j))) (setq pt1 (polar pt 0.0 12.5)) (setq pt2 (polar pt 0.0 50)) (setq pt3 (polar pt 0.0 85)) (setq t1 (substr S 1 4)) (setq t11 (strcat n t1)) (setq t2 (substr S 5 18)) (setq t3 (substr S 23 32)) (command "text" "m" pt1 3.0 0.0 t11) (command "text" "m" pt2 3.0 0.0 t2) (command "text" "m" pt3 3.0 0.0 t3) (setq p4 (polar p4 (/ (* -1 pi) 2) 10.0)) (setq p5 (polar p5 (/ (* -1 pi) 2) 10.0)) (setq p6 (polar p6 (/ (* -1 pi) 2) 10.0)) (setq p7 (polar p7 (/ (* -1 pi) 2) 10.0)) (command "offset" (+ j 10.0) (list L4567 p4) p1- "") (setq new (entlast)) (command "extend" new "" (list L14 P4) "") (command "extend" new "" (list L285 p5) "") (command "extend" new "" (list L96 p6) "") (command "extend" new "" (list L3107 p7) "") (setq j (+ j 10.0)) ) ;(close) (close fill) ) (defun dtr (x) ;define degrees to radians function (* pi ( / x 180.0)) ;divide the angle by 180 then ;multiply the result by the constant PI ) (princ) Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 3, 2015 Share Posted March 3, 2015 (edited) A couple of suggestions you seem to be doing a lot of layer make, why not just check for layer if not exist then make it and then just use (setvar "clayer" yourlayername) Maybe also use mtext saves working out each row. Note the double slash P "\\P" is used for new line, and you use Strcat to join it all up. (setq mytext (strcat "Row1" "[url="file://\\P"]\\P[/url]" "row2" "[url="file://\\P"]\\P[/url]" "row3")) (command "MTEXT" "0,0" "Height" 50 "Width" "0" mytext "") Last (setq p (getpoint "\nselect point press <Cr> to exit:")) (if (= p nil)(exit)) Edited March 3, 2015 by BIGAL Quote Link to comment Share on other sites More sharing options...
karim-salem Posted March 3, 2015 Author Share Posted March 3, 2015 thank you for your support. yesterday i added an upper limit for the main loop and it did work for me. (defun run () (setq pll (getstring "\nPlease Enter of new file (name.ext) :")) (setq pl (open pll "w")) (setq ang ( getreal "\nPlease Enter DV Angle: " ) ) (setq n ( getstring "\nPlease Enter TAXI name: " ) ) (initget (+ 1 2 4)) (setq a ( getint "\nPlease Enter number of first MH : " ) ) (setq als ( getint "\nPlease Enter number of last MH : " ) ) ;(setq e (getstring "\nget no. of first Point :")) ;(setq a (atoi e)) (while (<= a als) (setq aa 1) (while (<= aa 4) (setq p (getpoint "\nselect point :")) (setq v1 (strcat "\n " (itoa a) "-" (itoa aa))) (setq d (polar p (dtr 90) 0)) (setq f (itoa aa)) (setq k (itoa a)) (setq g (strcat n "-" k "-P-" f)) (command "layer" "m" "number" "c" "3" "" "") (command "text" "m" d 0.2 ang g) (setq num (entlast)) ;(command "change" num "" "layer" "" number "") (command "change" num "" "p" "layer" "number" "") (command "layer" "m" "point" "c" "1" "" "") (command "point" p) (setq pt (entlast)) ;(command "change" pt "" layer "" point "") (command "change" pt "" "p" "layer" "point" "") (setq x (car p)) (setq x (rtos x 2 4)) (setq x (strcat " " x " ")) (setq v2 x) (setq y (cadr p)) (setq y (rtos y 2 4)) (setq y (strcat y " ")) (setq v3 y) (princ V1 pl) (princ v2 pl) (princ v3 pl) (setq aa (+ aa 1)) ) (setq a (+ a 1)) ) (command "layer" "m" "txt" "c" "5" "" "") (close pl) (redraw) (princ) ) i will try to optimize using your suggestions, i hope i don't mess things up. thanks for everything mate Quote Link to comment Share on other sites More sharing options...
