zwei_kat
Xref - rotate - causing fatal error in AutocadLT 2015
zwei_kat
We have an ongoing problem running AutocadLT2015 with Xrefs causing fatal errors accross a few computers in our office.
What happens is:
Error occurs after deploying an existing acad dwg into the 2015 file (which saves as 2013).
Select Xref, Clip Xref, and then rotate Xreflaunches the fatal launch error 'runtime error' R6025 - pure virtual function call
We have tried:
Save out to a DXF file, re-launch Acad, and audit always yields 81 errors (fixed), re save as a dwg and re-launch.
But the problem keeps on happening!
Share this post
Link to post
zwei_kat
Ok thanks will give it a shot!
Share this post
Link to post
RobDraw
I cannot verify this but I think I've seen that fatal error before. The cause may have been the layer that the clipping boundary was on was locked or frozen.
Share this post
Link to post
SLW210
That message is associated with Windows, Microsoft Visual C++ Runtime Library Runtime Error and the best solution for AutoCAD has been a complete uninstall and reinstall.
I could post a bunch of steps for fixing the Microsoft Visual C++ Runtime Library, but much easier to uninstall and reinstall IMHO.
Share this post
Link to post
