sandiegophil Posted March 5, 2015 Share Posted March 5, 2015 Hello, I am hopeful that someone has found a way to utilize or extract the data in the surface properties --> statistics --> volume list for use in an expression for a volume label. I want to be able to create labels that let me dynamically show volume comparisons. Any and all help is appreciated. Thanks, Phil Quote Link to comment Share on other sites More sharing options...
C3D_TomR Posted March 6, 2015 Share Posted March 6, 2015 Surface Statistics Label from Red Transit Consultants, LLC. This may not be exactly what you requested but it might be useful. https://apps.exchange.autodesk.com/CIV3D/en/Detail/Index?id=appstore.exchange.autodesk.com%3ac3dsurfacestatisticslabel%3aen --Tom Quote Link to comment Share on other sites More sharing options...
BIGAL Posted March 6, 2015 Share Posted March 6, 2015 As the volume is a surface you should be able to get at its properties using this as a start (setq ss (ssget "_:L" '((0 . "AECC_TIN_SURFACE")))) and using dump should be able to step through and check the properties and see if cut and fill are available, will have to make a job to test etc If some one else does not post first. Quote Link to comment Share on other sites More sharing options...
sandiegophil Posted March 7, 2015 Author Share Posted March 7, 2015 thanks all for the information. Quote Link to comment Share on other sites More sharing options...
