Karnak
Hi there, hopefully this is just me being dumb.
What I have is an object that I have made into a block,
It has a vertical component, which can rotate 6 deg. clockwise and 11 deg. anti-clockwise.
Problem is, I need to limit the rotation 11 deg one way 6 the other, as the default location needs to stick at vertical.
The rotation parameter, as far as I have experienced, only allows me to limit movement in one direction, so it can rotate 17 deg. clockwise. Or 17 deg. anticlockwise.
What am I doing wrong?
Thanks
Share this post
Link to post
steven-g
You can limit the rotation between 2 angles - minimum and maximum. Can you post a copy of the block it would be easier to answer if someone can actually see what you are trying to do.
Share this post
Link to post
Karnak
Hi there,
Attached is a quick file that illustrates the problem.
As you can see, I have limited the range that it can move, but for some reason which is likely my fault, it only rotates one way with the range set.
Which would be fine were it not that the default location needs to be vertical, not at the base.
Hope this makes more sense
Example.dwg
Share this post
Link to post
steven-g
Is this something like, what you want to do. Or do you need to use actual negative values for the input.
Example.dwg
Share this post
Link to post
Karnak
Steven,
That's exactly what I wanted to do, thank you.
I can see what I was doing wrong now. - aka I was doing it completely wrong.
Brilliant :) this has been annoying me for a few days and I couldn't find any relevant/useful info that told me how to do it correctly.
Thanks again,
Share this post
Link to post
steven-g
You weren't far off, all I did was adjust a few of the angles in the properties toolpalette.
Share this post
Link to post
loren martell
Steven,
I looked at the example you supplied for Karnak.
I am not seeing how to accomplish ( see attached file for what I am trying to accomplish ). I would appreciate any help.
Thanks
-lm
SPF 200-050_Limited.dwg
Share this post
Link to post
