muck Posted April 1, 2015 Share Posted April 1, 2015 Is there a way to change AutoCAD versions that Debug uses? I have VS 2010 C Sharp express and my program debug is set for AutoCAD 2014. I want it to work on AutoCAD 2013. Is there a way I can reset that with VS express? Thank you, Quote Link to comment Share on other sites More sharing options...
BlackBox Posted April 1, 2015 Share Posted April 1, 2015 Is there a way to change AutoCAD versions that Debug uses?I have VS 2010 C Sharp express and my program debug is set for AutoCAD 2014. I want it to work on AutoCAD 2013. Is there a way I can reset that with VS express? Thank you, There are only two ways, using Express, that I know of: 1 - Add a new AutoCAD .NET Wizard Project to your Solution, targeting 2013, and copy in your code. 2 - Manually modify the .[cs/vb]Proj.User (XML) file's StartProgram XmlNode's value. Cheers Quote Link to comment Share on other sites More sharing options...
muck Posted April 1, 2015 Author Share Posted April 1, 2015 Do I need a text editor to do option 2? How do I edit that file? Once I am in the file do I change Acad 2014 to Acad 2013 or something like that? Thank you, Quote Link to comment Share on other sites More sharing options...
BlackBox Posted April 1, 2015 Share Posted April 1, 2015 Do I need a text editor to do option 2? How do I edit that file? Once I am in the file do I change Acad 2014 to Acad 2013 or something like that? Thank you, A project's .csproj, and .csproj.user files are just XML, so any text editor will do (Visual Studio, Notepad, Notepad++, etc). You should see the file path for 2014 listed within the nodes; just swap the file path for the correct one pointing to 2013. Cheers Quote Link to comment Share on other sites More sharing options...
