GopinadhGvs
How to Getvar from List Command Autolisp..?
GopinadhGvs
Hi All,
How to getvar from "list" command..?
When we type list, select a line then it will print the results like (length, from point, to point etc..) in a textscr..
when i tried to getvar "length", it is returning nill.
can any one help me in doing this...
Share this post
Link to post
jonathann3891
getvar only gets autocad variables.
Share this post
Link to post
GopinadhGvs
Hai jonathann3891,
Thanks for your reply,
I am using getvar "area" to get the "area" value, using area the area value is printing on the command line..
The problem that iam getting in "List" is, here the value is printing on "textscr"..
If it is printing on command line, i think i can use getvar to get the printed values..
Share this post
Link to post
BIGAL
Some variables are saved like, lastpoint, same also with properties it will display some properties but not necessarily evey one you want.
Use VL lisp to get properties
(alert (strcat "Length is " (rtos (vla-get-length (vlax-ename->vla-object (car (entsel)))) 2 3)))
Share this post
Link to post
neophoible
Hai jonathann3891,
Command line is really part of the textscreen. Though you can copy and paste from the textscreen, I don't know of a way to capture the info using AutoLISP. Note that, though the area is being printed to the textscreen, that is not where getvar is getting the value. If you gave a concrete example of what you are trying to do, you might get more specific help.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
