Thanks Lee, you'll get there too.
David produces some nice code as well. :)
  • Replies 25
  • Lee Mac
    13
  • CAB
    4
  • johnengineer
    3
  • ReMark
    2
Yeah he does, I like the way he shows his knowledge of the LISP functions - like using (while (not (minusp... instead of (while (> ... 0)
CAB, I was just analyzing the code you posted for the min, max, average LISP and happened to stumble across this line:
(setq lst (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))))
[/code]
I have tried experimenting with this line to see what you are trying to achieve, by using the below code and analysing the results of each selection:
(defun c:test2 (/ ss)
   (setq ss (ssget '((0 . "TEXT,MTEXT"))))
   (listp (mapcar 'cadr (ssnamex ss)))
) ;_  end defun
But it seems whatever text I select the result is always T. Which makes me wonder what this line of code is actually used for?
Any help or advice would be much appreciated :)
Thanks
Lee
When you use a windowed selection method a sub list is returned with ssnamex like this:
(setq lst (mapcar 'cadr (ssnamex ss)))
<Selection set: 84>
(<Entity name: 1c93b18> (0 (1788.41 2356.59 0.0231568)))
To remove the unwanted list you use this:
(vl-remove-if 'listp lst)
(<Entity name: 1c93b18>)
Ahh, I understand it now - so its just a cool way to retrieve the entity name.
Very nice CAB
  • 14 years later...
I am working with Attribute objects and need to calculate the Max, min, Average values of several same Attribute objects selected from Select.
I don't understand much about Lisp, so I hope you can help me with the following Lisp:
1. Commad: MaxminAve
2. Pick select Block Att template
3. Choose to pick Block Att's sample Tag
4. Select the Select area
5. Pick the resulting text setpoint
For example:
- In the drawing there are many different Block Att, in which there are also many Block Att "FFFFFFFF"
1. Command: MaxminAve
2. Pick to select Block "FFFFFFFF"
3. Pick the tag "CCoss" of Block "FFFFFFFF"
4. Select Block selection area (For example, I can Select in an area with 5 blocks Att "FFFFFFFF")
5. Pick the result set point
The result will be the Mtext with the current Layer and Mtext present in the drawing:
"- Number Select Att = 5 blocks Att
- Number max = ????
- Number Min = ????
- Number Ave = ???"
Can someone help me?
Thank you very much in advance
(My English is very bad, I hope everyone can understand)
Edited by SoftvnBin
