slimpickinz Posted April 23, 2015 Share Posted April 23, 2015 Tried to attach a blank drawing (but exceeds max size), which has been cleaned up as much as I can... purged, detached X-REFS, ran Superpurge, kicked around and otherwise abused... Still cannot get rid of all these linetypes pickup up from copy & paste of another drawing. Will post link to drawing as soon as I can upload to my server... Any ideas?? Thanks! -SlimP Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 23, 2015 Share Posted April 23, 2015 My guess is, without seeing the full linetype name, you have tons of Microstation linetypes being loaded. Have you tried the old trick of WBlocking out your drawing? Quote Link to comment Share on other sites More sharing options...
slimpickinz Posted April 23, 2015 Author Share Posted April 23, 2015 hmmmm... think so, but will try again... here is a link to the DWG http://dkdesigns.us/docs/blank-w-linetypes.dwg Quote Link to comment Share on other sites More sharing options...
slimpickinz Posted April 23, 2015 Author Share Posted April 23, 2015 Nope, didn't work. A tell tale sign something is a miss in that the "blank" drawing is 1.3MB. Not good. Take a peek at the drawing... maybe you will see something I am missing. -SlimP Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 23, 2015 Share Posted April 23, 2015 Well the linetypes were not from Microstation so I was wrong there. I think they may have been from an AutoCAD vertical product (Civil 3D?). Anyway, I got the file size down to 56KB. Anything else you need me to do with it? Quote Link to comment Share on other sites More sharing options...
slimpickinz Posted April 23, 2015 Author Share Posted April 23, 2015 yeas please... tell me how you did it! I have many many drawings that are in need of attention. And I am only running LT 2012 here at work, but do have a LISP machine at home.. ACAD2015. Quote Link to comment Share on other sites More sharing options...
slimpickinz Posted April 23, 2015 Author Share Posted April 23, 2015 & can you do the trick on this one? It is a basic shop drawing that I am having problems with... http://dkdesigns.us/docs/test002.dwg Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 23, 2015 Share Posted April 23, 2015 I did not use lisp. I used the EXPORTTOAUTOCAD command. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 23, 2015 Share Posted April 23, 2015 & can you do the trick on this one? It is a basic shop drawing that I am having problems with... http://dkdesigns.us/docs/test002.dwg Yes, I can. 97KB (using the WBlock trick). I can also guess the card you're holding. Quote Link to comment Share on other sites More sharing options...
slimpickinz Posted April 23, 2015 Author Share Posted April 23, 2015 thanks. Will give it a try. WBlock the whole drawing, then... Did not work for me though. hmmmmm... Quote Link to comment Share on other sites More sharing options...
slimpickinz Posted April 23, 2015 Author Share Posted April 23, 2015 post drawing back please? Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 23, 2015 Share Posted April 23, 2015 Sorry, couldn't resist... Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 23, 2015 Share Posted April 23, 2015 WBlock did work for me. Unfortunately I am not on my CAD computer at the moment so I cannot attach a copy of the drawing. Quote Link to comment Share on other sites More sharing options...
RobDraw Posted April 24, 2015 Share Posted April 24, 2015 ... and there it is. Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 24, 2015 Share Posted April 24, 2015 The seven of clubs. Cleaned up using the WBlock command. Saved in 2010 file format. Test002_Magic.dwg Quote Link to comment Share on other sites More sharing options...
slimpickinz Posted April 24, 2015 Author Share Posted April 24, 2015 Thanks! Lucky guess on that 7 of clubs though... I will do research on that WBLOCK cleanup method and try it on some of these drawings. -SlimP Quote Link to comment Share on other sites More sharing options...
slimpickinz Posted April 24, 2015 Author Share Posted April 24, 2015 I am thinking that this is a LT vs Full Version issue as I had another user running ACAD 08 Full Version simply WBLOCK the entire drawing and it cleaned it up nicely. Did the exact same thing with this ACAD LT 2012 and did not work. Thoughts? And see if your magic is working this morning oh mighty one.... Quote Link to comment Share on other sites More sharing options...
ReMark Posted April 24, 2015 Share Posted April 24, 2015 Ace of spades. I could test your theory re: full AutoCAD vs. LT when I get back to the office on Monday. I am working off-site today. Quote Link to comment Share on other sites More sharing options...
slimpickinz Posted April 24, 2015 Author Share Posted April 24, 2015 which card am i holding? Quote Link to comment Share on other sites More sharing options...
slimpickinz Posted April 24, 2015 Author Share Posted April 24, 2015 DAMN! YOU ARE GOOD. Ok, thanks... keep me posted. Anyone else test this out for me? The dwg cleanup not the card trick... Quote Link to comment Share on other sites More sharing options...
